Need Help Quick Please!
Old 01-31-2004, 07:37 PM
BriGuy's Avatar
Default Need Help Quick Please!
I was in the process of changing my wife's valve seals. Started on the exhaust side of #8. Had the air hose connected in the plug hole with 90psi. Popped off the seal and was not able to catch the valve before it dropped. I can not see the valve anymore but when I stick a pen magnet down the hole I can feel the top of it faily easily (without the magnet going too far down). Is there any way at all possible to get this valve up without pulling the heads??? Any help would be greatly appreciated!
Old 01-31-2004, 07:43 PM
more carbon's Avatar
how far down is it,can you turn your engine over with the crank bolt to lift the valve with it on the magnet at the same time????
Old 01-31-2004, 07:47 PM
jrp
SN95 Director
jrp's Avatar
another reason i like the TDC method over the air method. you can try what the above guy said but i think your gonna have to pull the head
Old 01-31-2004, 08:16 PM
piston should be most of the way up before you disconnect,isn't that standard procedure?????
Old 01-31-2004, 09:37 PM
BriGuy's Avatar
Yes, thank you so much. It worked.
Old 01-31-2004, 09:41 PM
wrench-on my friend!!!!
Old 02-01-2004, 02:34 AM
BriGuy's Avatar
Well, to prevent any more of those problems I used both the air and the top dead center method to finish up the seals and when putting on the springs.
Old 02-01-2004, 06:07 AM
TT-TECH Veteran
Inspector12's Avatar
You got lucky my friend! But I am glad for you. I have never had a problem doing valve spring or seals with air. But then again I am luck also.
Old 02-01-2004, 06:09 AM
Scott Turvey's Avatar
Dude, that is nothing short of a miracle...
Old 02-01-2004, 08:13 AM
Scalpel's Avatar
I don't know how you pulled that off but you should have bought a lottery ticket when you did that.
Old 02-01-2004, 10:22 PM
SS SLP2's Avatar
just a note : I use air and TDC both but the air rolled the piston down ( at 60 psi and all plugs in except the one we were on)we had left the second spring fron rear off while removing the rear spring, some way bumped the value and lost air pressure and ALLMOST droped both values on that cyl.
so you need to watch that the air does not roll piston down ( on my car 59-60 psi will roll piston to complete bottom- 51 k on car, a4, and use no oil )
just my .02's Johnny
Old 02-01-2004, 10:30 PM
jmX
jmX's Avatar
I disagree about it being a miracle...I've seen that happen like 4 times now (on various cars) on an LS1....and I've *never* seen it fall all the way in. I'm not even sure its possible now after that kinda record.
Either way, as others said, turn the motor and it comes right back up.
