Car Ls1 Intake on 5.3 Truck Engine?
Old 11-03-2010, 04:27 PM
1985fiero's Avatar
Default Car Ls1 Intake on 5.3 Truck Engine?
I have a car ls1 intake for my boosted 5.3 motor I am putting together. I understand that I will have to swap out waterpump, balancer along with accessories for it to work.
Now my question is will the balance be ok still using the 5.3 truck engine flexplate with a car ls1 balancer?
arent all ls engines internally balanced?
Old 11-03-2010, 04:43 PM
LS1TECH Sponsor
Carshopinc.com's Avatar
No problem.... all internal on the front hub... I might have a solution for the accesories
with out changing balancer and water pump...
Tim
Old 11-03-2010, 04:57 PM
1985fiero's Avatar
so mixing a truck flexplate with a car ls1 balancer on a 5.3 truck motor is ok and wont cause any problems?
And what do you have solution wise for the accessories
Old 11-03-2010, 06:30 PM
bww3588's Avatar
it will not cause problems. LS engines are internally balanced and the balancer and flexplate are 0 balanced.
Old 11-03-2010, 06:33 PM
zipster's Avatar
I keep bringing up my photobucket to let people know what I did with my water pump and accessories. Check it out. LS1 intake on a 6.0 with truck accessories and water pump.
Old 11-03-2010, 08:11 PM
1985fiero's Avatar
I like your style. I see you put a freeze plug in where the old pipe was but what did you do to open the port on the front of the waterpump
Old 11-03-2010, 08:17 PM
zipster's Avatar
1 1/4 hole saw, and ground groves in the threaded end of a pipe and used it as a large tap. Once the threads were sufficient, I threaded in a piece of pipe that was the same size of the old tube I removed from the top.
Old 11-03-2010, 09:33 PM
gofastwclass's Avatar
Honestly you don't have to get that creative. All I did was trim the throttle body a bit and it works completely fine. There is a place that sells a 1/2" spacer but I can't remember where I saw it, but that would create the clearance you need as well. I didn't discover the spacer until after I had modified my TB. The swap is over a year old and has over 10K miles of daily abuse on it without issue. You can see photos of my mod on this link or my signature for a link to my complete build topic.
I'm using a custom accessory drive but I needed that to fit the vehicle. I did absolutely nothing to the water pump because if I'm ever stranded 50 miles from a major city all I'll probably have access to is cheap parts store hand tools and I can still repair my car. I'm just not a fan of modding a wear part that may die and can't easily be repaired road side.
Old 11-03-2010, 09:39 PM
1985fiero's Avatar
thanks for the responses I think I will use a ls1 wp and balancer
Quick Reply: Car Ls1 Intake on 5.3 Truck Engine?
