low oil pressure, help!
Old 11-03-2010, 05:55 PM
FLASHhat's Avatar
Default low oil pressure, help!
Have a 2004 6.0 in a GMC Yukon denalli. 113,000 miles.
Low oil pressure light came on, pressure is 0 at idle, 20 psi at 35 mph.
Had sensor checked out ok, changed oil and filter and pressure is better but still low.
checked with mechanical gauge and pressure is low.
Had shop pull pan and it appears # 2 cam bearing has moved approx. 1/8" back.
(see attached photo's), if this is the case would this cause low pressure?
Can cam be removed, new bearing installed and reassembled and be good to go?
Or is there more to repair?
Thanks for the help.
Attached Thumbnails low oil pressure, help!-img00102-20101103-1601.jpg   low oil pressure, help!-img00103-20101103-1602.jpg
Old 11-03-2010, 06:29 PM
Fastdriver1992's Avatar
it shouldnt be that low. what u need to check is this plug if it fell out or is missing. happend to my friends block had like no oil pressure @ idle and like 20lbs @ 2500 rpms
http://image.chevyhiperformance.com/...i_oil_pump.jpg
Old 11-03-2010, 09:40 PM
SOMbitch's Avatar
Yes that will and can cause your OP problem but if that happened it makes me wonder why and if anything else may be F'd too... My 208K 99 5.3 idles 45# and at 2K runs 55# on 5w-30......
Old 11-07-2010, 07:50 PM
my car idles 50lbs @ 1000 @ 180 degrees and 80lbs @ 6000rpms wit 10w-30
Old 11-07-2010, 10:58 PM
Mr MasterCraft's Avatar
My 225k '02 5.3L idles at 53# and anything above 1800RPMs, it sits at 75#. Get on a set speed for more than 30 seconds or so and it'll drop down to 65# and stay constant until the throttle position changes
Edit: Forgot to add the most important part. Previous owner stated he had some sort of LS6 drilled oil pump installed. Duno how much truth there is to it, but whatever. I'm happy with it.
To the OP, I'd take the pictures and info and roll with it... seems like you're already shooting between the lines
Quick Reply: low oil pressure, help!
