Slow Z06 needs help
Slow Z06 needs help
Buddy Has a 03 Zo6 and hes really upset my stock headed stock intake LT1 beats his ***. So now hes interested is Having his stock heads done with a custom cam. Who should he call. I know who Id call for a Lt1 just not possitive for a LS6. Shop names and tack times help. Thanks for the help.
Hey Ac,
Here is a link to some pretty impressive results:
https://ls1tech.com/forums/dynamomet...k-results.html
The nice thing about the eps lobes is that they are very easy on valve springs compared to xer, lsl and lsk lobes! Contact Patrick G or Geoff they can provide you with better details!
He will do all the supporting mods needed without a doubt. My car has been 11.6@120 NA leaving a lot on the table with LE stock ported heads/ intake & custom cam . His has been 12.3@113 so he has some work to do, but im sure it will go faster once he has the same mods. Again he doesnt want a drag car, just a wicked DD type car.
w/ LTs + CAI + cam he should be 400+ rwhp easy maybe hitting 420. After that it all depends on how much $$$ he wants to sink into the top end.
I'd call up TSP (actually going to probably order my cam swap parts through them).
Ac, in that link I posted, he made 430whp w/ a stock ls6 long block and ls6 intake!! That was thru a stalled a4 too! he went low 11's @120+. I think if your buddy went with that cam, he would see upwards of 450whp thru the m6 and drive like stock!! Pretty sure that cam was designed specifically for a stock headed ls6 motor...
Not tryin to argue but don't Geoff @ eps use his own "lsg" lobe? are they not different than lsl lobe, correct me if Im wrong? I agree from everything I have read the eps lobes are definately easier on springs... If I ever get a cam it would be from him!!
Yes Geoff uses a proprietary lobe he developed but they are similiar. He and I discussed this when I ordered my cam from him......
