Porting hole in intake 243 head
Old 11-15-2010, 05:44 AM
Mar10n's Avatar
Default Porting hole in intake 243 head
Hello
I just bought some ported 243 heads. they are ported so much that the bolts from the valve train is sticking a little out of the intake wall.
I found a pic that have the same hole after porting. Is this normal? should I do anything with the hole?
pic
[img]https://i137.photobucket.com/albums/q219/EDC-FTI/243IntakeThroat.jpg[img]
Old 11-15-2010, 05:45 AM
Mar10n's Avatar
why wont the image link work?
Old 11-15-2010, 05:59 AM
Nitroused383's Avatar
It's normal, run some thread sealant on the bolts.
Old 11-15-2010, 06:26 AM
Darkman's Avatar
https://ls1tech.com/forums/generatio...bolt-area.html
Old 11-15-2010, 10:56 AM
slt200mph's Avatar
Very much normal as was mentioned before use thread sealer on the pushrod bolts...you might want to get a shorter set of bolts so that they do not protrude into the intake port which will disturb your air/fuel charge flow.
