5.3 heads milling
Old 11-15-2010, 09:35 AM
does's Avatar
Default 5.3 heads milling
does any one no how much you can mill off 5.3 head useing 570 lift cam and 7.4 push rod 202 intake vavle and be safe
Old 11-15-2010, 09:37 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
What is the duration on the cam? That determines piston to valve more then lift on the cam does.
Old 11-15-2010, 09:41 AM
does's Avatar
228 230 sorry
Old 11-15-2010, 09:45 AM
does's Avatar
this is the comp cam 228.230 570 571
Old 11-15-2010, 10:15 AM
I would think you could safely cut those heads .020" with that cam. Maybe farther but you would definately want to measure your piston to valve to make sure you will be ok. Once milled .020" the heads should be at a 60cc chamber.
Old 11-15-2010, 10:23 AM
does's Avatar
thanks man what would you guys charge to cnc port these heads
Old 11-15-2010, 10:52 AM
Right at 750 for CNC port and CNC valvejob. We can also put larger valves in for an extra $200 if requested.
