Installing an ls2 timing chain damper on an LQ9
Old 11-15-2010, 10:03 AM
Old School Heavy
speedtigger's Avatar
Default Installing an ls2 timing chain damper on an LQ9
My LQ9 did not come with a timing chain damper. I was considering installing the LS2 timing chain damper:
My block is not drilled for a damper, but it has a machined flat area that looks as if it could be drilled. Has anyone done this? Advice to make it go smoothly?
Old 11-15-2010, 10:10 AM
The_Rizzle's Avatar
If you're going to do the work, I highly suggest the LS3 tensioner. Same bolt pattern, but works better.
I have no advice on how to do it, but am doing this myself to a 4.8 soon. My l33 had the proper bolt holes.
Old 11-15-2010, 10:53 AM
Old School Heavy
I would consider the LS3 damper but I read a couple post where they complained that the LS3 damper had broken.
Old 11-15-2010, 12:21 PM
LSX Mechanic
Damian's Avatar
If you insist on having a dampner, the motor needs to get pulled and broken down. Then drilled/tapped by a machine shop.
I would not. I repeat, WOULD NOT drill into your block with it fully assembled. Especially without the tools to precisely place the holes.
Old 11-15-2010, 01:05 PM
Old School Heavy
I guess you won't be installing any then.
The following users liked this post:
Blac94z28 (02-03-2020)
Old 11-25-2010, 02:15 PM
Old School Heavy
Looks like I have to man up and admit that it turns out you are right on this one after all.
Here is why:
It turns out that the bolts that hold the dampener in place are quite long. And, as you can see in the picture, the area of the block to be drilled is fairly thin comparatively speaking. So, in order to drill and tap this area to accept the dampener's retaining bolts, this section of the block would have to be drilled all the way through.
Unlike just drilling a bottoming hole, with a through hole there would be no way to keep all of the cast iron shavings from drilling and tapping out of the inside of the shortblock. Since I do not intend to disassemble the shortblock, I will pass on this mod.
Attached Thumbnails Installing an ls2 timing chain damper on an LQ9-ls2-dampener.jpg
Old 11-25-2010, 09:28 PM
brngrhd's Avatar
when is this mod a needed thing?
Old 11-25-2010, 09:44 PM
The_Rizzle's Avatar
Its not "needed" per say, its just that it makes you feel better about using the sloppy ls2 chain.
Old 11-26-2010, 02:25 PM
ls1 1990 VN's Avatar
Road Racing!!! My Dual rollmaster broke causing a fair amount of damage.
Old 11-18-2011, 12:05 AM
ShredSled's Avatar
Has anybody ever followed through with this on an iron block?
Old 02-26-2012, 07:19 PM
06X6spdGTO's Avatar
BAck from the dead!!! Anyone ever do this on your Stock bottom Iron block??? Looking for billyflantos here!! He thrashed his Fox body pretty hard on the LQ4
Old 02-26-2012, 07:47 PM
ShredSled's Avatar
I never bothered... Had the shortblock built by the time I had researched more and realized you drill through block all the way I beleive. Didn't want to deal with shavings...
Quick Reply: Installing an ls2 timing chain damper on an LQ9
