crack oil pan
Old 11-15-2010, 05:01 PM
skully's Avatar
Default crack oil pan
Need help on this one im not to mechically incline ..just trying to see what yall think before i take it to the shop.My wife went to start her 2002 trans am an it made a loud noise so i look under the car and the oil pan is crack bad! Thanks
Old 11-15-2010, 05:08 PM
Darkman's Avatar
Hard to say, but the only experiences I have had with oil pan breakage involved castrophic failure of the rotating assembly.
Old 11-15-2010, 05:21 PM
skully's Avatar
well thats what puzzles me cause it happen on crank up!
Old 11-15-2010, 05:27 PM
Whiteaw57's Avatar
you probably shot a rod out the side or something. we really dont have enough information
Old 11-15-2010, 05:28 PM
DaveX's Avatar
I have heard of this happening, but from what I remember the damage is usually more extensive than the pan. Pull the starter and check the block for damage. I seem to remember something about an ear breaking off of the block.
Old 11-15-2010, 05:31 PM
skully's Avatar
So is this common with just starting the car up ?
Old 11-15-2010, 05:35 PM
Whiteaw57's Avatar
no if theres a cracked pan thats not good if theres oil everywhere thats worse if theres a hole thats terrible. what happened did the engine shut itself down or did it run until you cut it off
Old 11-15-2010, 05:54 PM
skully's Avatar
Well thats whats crazy she said it never crank . She truned it over but it never fired off ...if it did it was only couple of seconds!
Old 11-15-2010, 05:59 PM
Whiteaw57's Avatar
sry man take it to a shop
Old 11-15-2010, 06:03 PM
skully's Avatar
Thanks bro for the info!
Old 11-15-2010, 06:04 PM
Whiteaw57's Avatar
sorry we couldnt help more
Old 11-15-2010, 09:32 PM
DaveX's Avatar
https://ls1tech.com/forums/general-m...ock-broke.html
Hopefully yours does not have the same problem.
Old 11-21-2010, 12:40 PM
skully's Avatar
Davex thank you for the link.......i have been so pissed at the car that i havent even jacked it up and look at the starter !!!!
Old 11-21-2010, 02:13 PM
NVR_SPDS's Avatar
Jack it up, and get some pics. that will be the best way to help you.
Old 11-21-2010, 02:18 PM
desertLS1's Avatar
That sux man, sorry to hear.
Old 11-21-2010, 05:44 PM
O2Form's Avatar
Was it raining just before this happened? Because they all leak water past the cowling onto the engine. If any injector orings or the intake gaskets leak a little and let rain water into the engine. The high reduction starter GM uses will allow a simple hydro lock to turn into a broken block. Good Luck
