Best Cam for 243 heads?
Old 11-17-2010, 06:56 AM
beerman985's Avatar
Default Best Cam for 243 heads?
I am going with the 243 heads. i have a ls6 intake,long tubes, hot wire fuel pump,and have a set of 32 injecters.
I am planing on geting good springs,keepers,rockers,oil pump,timing chain,ect
I want a some what chopy idle so you can hear the cam, but have ok drive ablality,car is only driven on weekends and is driven to and from the track.
any inputs would be great... Im in a va, so would also be looking for a good tuner.
Old 11-17-2010, 07:25 AM
Tobias05's Avatar
Steve Frost is in VA.
you want something off the shelf, or custom?
shelf cam I'd go with 228r or 233, custom I'd prolly go with EPS. They seem to be building a reputation.
Old 11-17-2010, 08:01 AM
beerman985's Avatar
it really doesnt matter this is my first cam and heads ever. I really just want the head to be good for F.I. later down the road after i get out of school. I just want to make a round 450 hp now is that possable with those heads and a really good cam..
Old 11-17-2010, 08:16 AM
Tobias05's Avatar
https://ls1tech.com/forums/dynamomet...k-results.html
Old 11-17-2010, 08:35 AM
mtuggle86's Avatar
I went with a Pat G custom spec eps cam Ill give you a review of it as soon as it gets here.
Old 11-17-2010, 08:43 AM
LS1TECH Sponsor
mikey's Avatar
Do a search on my Dominator 2 cam. Nice lopey idle, good driveability and great power.
Mikey
Old 11-17-2010, 10:51 AM
01ssreda4's Avatar
What gears you gonna be running OP?
Old 11-17-2010, 10:56 AM
NC98Z's Avatar
TSPs TV2 has a nice chop to it and is very streetable. If you get your heads ported you might make 450rwhp. But cam only I doubt its possible.
Old 11-17-2010, 11:14 AM
JustAnotherLS2's Avatar
Correct me if Im wrong, I probably am; LSA has more to do with choppiness of idle comparing to duration/lift?
Old 11-17-2010, 11:27 AM
beerman985's Avatar
my gears are 4.11 in a 9in.
Quick Reply: Best Cam for 243 heads?
