valve springs
valve springs
ok so i just got this cam
99-TR-CHEATRLS2-CAM
http://www.thunderracing.com/shop-by...-Cams_944.html
scroll down and you will see it
it says "Comp 921 Valve Springs are highly recommended"
where can i find these for under 600 bucks, or can i used different ones because comp's prices are alittle high....
let me know guys, im new to the whole ls1 thing.
99-TR-CHEATRLS2-CAM
ok, so it says the comp 921 valve springs, if i were to get them from patriot what would those be called, im looking for one with certan lift right?
i just want to make sure i dont order the wrong stuff lol....
well whatever your cam spec is be sure to give yourself a buffer if its a .600 lift cam run a min of a .625 lift spring if not a .650 lift. On the other hand theres seat pressure to account for. usually a fairly normal ranged spring will be around 180# closed and 380# open. If youre running dual springs that open pressure will be higher. so I would say whatever the comp 921 specs are find the spring thats closest to that if theyre so insistent on a 921.
lol i know any brand will work now but im still unsure about what EXACT spring numbers im looking for... like i said, im new to the whole ls1 game... iv been a rotard for the past 5 years and have finnaly come to the dark side....
LS1Tech Premium Sponsor
Agreed!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
http://texas-speed.com/shop/item.asp...d=172&catid=48
ill probably go with this kit right here since the guy doing my motor told me to go ahead and get hardend push rods also.
and has anyone had any experiance with these?
and will this work for my cam specs?
"LS2 CheaTR" - 215/230 .629/.592 117 LSA
http://cgi.ebay.com/ebaymotors/LUNAT...item2eb14790a0
and texas speed, if you have what im looking for and have an ebay store, let me know, i have a ton of ebay bucks that i need to spend.
