camshaft for use with TFS 215 cyl heads
Old 11-18-2010, 06:57 PM
jt76's Avatar
Default camshaft for use with TFS 215 cyl heads
what are you guys running with these heads? I am not afraid to fly cut. My current cam is a 231/237 but i will switch it out if need be for heads and cam to work best together.
Old 11-18-2010, 07:54 PM
Darkman's Avatar
If you are not afraid to flycut, perhaps you should plan on it. That way you can maximize the cam duration and static compression ratio by milling the heads.
(I have 215s with a small EPS cam, which allowed me to bump the compression.)
Old 11-18-2010, 10:25 PM
jt76's Avatar
I just purchased a set milled to 58cc. I will be running a fast 90/90 as well. JW what people are running to maximize this setup
Old 11-19-2010, 07:09 AM
chrs1313's Avatar
https://ls1tech.com/forums/dynamomet...p-426rwtq.html
https://ls1tech.com/forums/generatio...track-car.html
I got a buddy getting the 3rd cam and we are putting it in a m6, should break 500rwhp no problem...
also you owe me big haha
Old 11-19-2010, 10:35 AM
JustAnotherLS2's Avatar
Nice.
Old 11-19-2010, 03:54 PM
Ws6kid.'s Avatar
Nice!
Old 11-20-2010, 10:22 PM
studderin's Avatar
streetsweeper cam, got great power that drives really good, or trex for a "little" more power but drives like a trex
Old 01-17-2011, 05:34 PM
jt76's Avatar
so i checked my PTV with my current cam:
looks like i need to cut regardless.. so once again open to some suggestions for a camshaft. I was thinking something in the neighborhood of an MS4?
Old 01-17-2011, 09:06 PM
garygnu's Avatar
do what CHrs1313 says or talk to Geoff at EPS .Geoff works with the trick flow heads and knows what they like.
