Blowing ALOT of smoke out the breather!!!!!
Old 11-25-2010, 12:37 PM
Fastdriver1992's Avatar
Default Blowing ALOT of smoke out the breather!!!!!
i have a breather put in the top of a t fitting between the valve cover and the valley cover vent. i have an ls6 valley cover and the breather is my only crankcase ventilation. now i know a guy who has had this problem (blowing alot of smoke out of the breather) and when he took the motor apart he had a bad ring. could this be my problem? i have not seen any loss in hp either. should i be worried?
Thanks
Anthony
Old 11-25-2010, 02:12 PM
thanksgiving bump lol
Old 11-25-2010, 05:05 PM
nandos_z28's Avatar
My guess would be bad rings as you suspected. Do a leak down test and it'll tell you which cylinder/cylinders are your problem.
Old 11-25-2010, 08:08 PM
GTO1_OHIO's Avatar
Exactly as mines doing. I'm also smoking out the tail pipes at WOT.. Leak down showed I was at 80% on #8 and 90% on #3. I couldn't notice a power loss on the street but I dropped over 30 rwhp between dynos as things were getting worse. Like it was said, smoke out a valve cover breather means that a ring(s) is bad.
Old 11-25-2010, 08:16 PM
taman86's Avatar
well **** mine is doing the same thing, i guess thats what happens when the car sits for 4 months without starting it. im not gunna lie, im kinda heart broken by this finding. i really dont have the money to do a bottom end rebuild. i dont have the tools and equipment to drop the motor or the proper place to tear down an engine. that sux
Old 11-25-2010, 08:24 PM
really not looking to tear this thing apart but i mean i raced the car for the passed 2 weekends that i've noticed this and i've been turning the 118-119mph that i have been doing all year with solid et's so i would think i would see a real drop in hp and mph i'll probably do a test over the winter just to be safe
Old 11-25-2010, 09:10 PM
AZZKIKR's Avatar
Mine was doing same thing (supercharged ZO6) about 200 miles later, ringland on #2 let go, piece of piston came off hit the spark plug causing the gap to close, cause a miss-fire, etc.. Working on the forged build now..
Old 11-25-2010, 09:17 PM
SH*T if i have to take this motor apart its gonna be a long off season... this car will never get painted lol
Old 11-25-2010, 09:29 PM
AZZKIKR's Avatar
Better than rebuilding during the "on" season.
Old 11-25-2010, 09:33 PM
absolutely might as well stroke the B*tch while i'm at it lol
Old 11-25-2010, 10:23 PM
taman86's Avatar
looks like im gunna be looking into parting out and using that money on another car
Old 11-25-2010, 10:39 PM
silverZ98's Avatar
do a leak down before you part it out make sure
Old 11-25-2010, 11:37 PM
nandos_z28's Avatar
In my experience I felt no change in power either. I never did a leak down as I just tore the motor down and repaired it. In my case the ringland on # 7 had broken off but the car seemed to run perfectly fine other than the smoke.
You could always just do a quick and easy replacement of the pistons that are damaged as long as nothing else is hurt. (cylinders, heads, valves etc...)
Old 11-26-2010, 01:42 AM
BlackShadowZ28's Avatar
Wow i was just about to post about this, i guess im going to get a leak down test soon then.
Old 11-26-2010, 07:51 AM
yeah defiantly gonna do a leak down test first. got 2 full years of racing on the motor so its time for a little refresher
Quick Reply: Blowing ALOT of smoke out the breather!!!!!
