Tapping and rough Idle
I had a slight tapping sound and a rough idle. I figured I had a bad lifter. I took the top of the motor apart getting to the lifters and when I got to the push rods I pulled all the push rods out, 1 was bent and another was bent and broke.
Any idels of what would cause this?
Thanks Guys!!!
Thanks Guys!!!
But would bent pushrods cause a sewing machine type sound on the bottom end? I cant really tell it may be my exhaust as I only stuck my head under there for just a minute or so.
I may have to do my valve seals soon and was just wondering if I should go ahead and do this. Not to mention my car is a stick and has high mileage.
Links to a good product?
I think nimrod meant noisy in the lower rpms, the answer is yes to a degree. Slightly bent pushrods means that there is going to be a little more lash at the rocker arms which is where you get the tick. The reason you hear it at lower rpm however is probably just because the exhaust isnt as loud there and also with the engine at slower speed theres more time between ticks which makes them more defined. when in doubt grab some though. I think tsp has them for 109$
remove your push rods out.roll your push rods on a flat surface,kitchen table or counter top.if you push rods are straight your lifters mite be bad at that high of mileage.look for broken valve springs or bad rocker arm trunnion bearing.ls1howto.com for instructions on removal of said pieces.
