Stuck lifter
Old 11-29-2010, 04:27 PM
zgut's Avatar
Default Stuck lifter
(1999 camaro ss) Im pretty sure i have a collapsed lifter and i pulled the intake and head. The lifter that i believe is the collapsed lifter is stuck but the lifter is sticking out about a 1/2 inch. Btw im doing this with the motor inside the car.. Should i just keep trying to pull it out by hand?
Old 11-30-2010, 04:32 AM
vettenuts's Avatar
No. If the lifters won't come out without force it may be damaged and not collapsed. Removing it from the top could damage the lifter bore. Pull the cam and drop the lifter out the bottom. Its more work but could save your block.
Old 11-30-2010, 11:32 AM
Whiteaw57's Avatar
Agreed with vettenuts, It really sucks but the cam is probably damaged anyway if the lifter is. Good luck with it
Old 12-03-2010, 12:56 PM
zgut's Avatar
Yes thats was it seems like.. Hopefully ill get everything off this weekend and im going to check the lobe on the cam.
