Hypereutectic Piston Question...
Everywhere I look I find info that says not to bore/hone the LS1 block more than .010" (.25mm). So why do Keith Black & Sealed Power / Speed-Pro offer hyper pistons up to .040" (1mm) oversize? Is the .010 rule-of-thumb only for nitrous or FI applications? What do you guys think?
KB #3498HC - page 65 from the 2009 catalog - here
Rock Auto has Sealed Power (Speed-Pro) #H868CP for an '02 Camaro - here
Both show .25mm, .50mm, .75mm, & 1mm oversize.
Summit sells both:
http://www.summitracing.com/parts/UEM-3498HC-1-0MM/
http://www.summitracing.com/parts/STL-H868CP75MM/
Summit sells both:
Moderator
You're probably right. I've heard of LS2's going out to 4.030" but I can't imagine that that would be something that would live long with a considerable amount of power. An iron 5.3L block would probably be fine at that bore. The hypereutectic piston would probably have problems before the cylinder would.
The following users liked this post:
tdmaker (03-12-2022)
