5.3 or 5.7 heads?
5.3 or 5.7 heads?
i cant decide what heads to get...?
i would like a CR between 10.5-10.8:1
which head will make more power?
which head is better........and why?
so should i get...
un- milled or slightly milled S2 5.3
or a set of 5.7 S2 heads......please help?
so should i get...
I would favor the 5.3's over the 5.7's. If you looking at heads TEA's 1.5's w/hand finishing will be very hard to beat. The 5.3's can have more compression with less milling this can tend to give a little more P to V clearance than a set of 5.7's that have to be milled more for the same compression. The 5.3 may have a better exhaust port to work with in stock form.
If your commited to PP's. I would get the PP 5.3's. Yesterday someone posted pictures of the PP 5.7 chambers and they are untouched. The top porters do a some chamber touch up. The 5.3's have some touch ups in the chambers.
i was thinking a 222/222 .563/.563 114
i know its small but im in CA. would like a 1500-6300 power band.
with good low end. any other suggestions.?
how did the porting look on those PP 5.3 heads.
where you satisfied......
