help with compression calculation
Old 12-09-2010, 02:57 PM
TXsilverado's Avatar
Default help with compression calculation
STOCK bottom end LQ9 6.0 (4" bore)
64cc heads
.040 compressed gasket
4.03 gasket bore
piston stroke 3.622
piston deck clearance ??????? i guess .005 above deck????
what am i looking at compression wise? 11.3-11.5ish? thanks gurus. i couldnt find ANYTHING about the piston deck clearance. someone educate me please
Old 12-09-2010, 03:14 PM
gotjuice?'s Avatar
to get the exact compression you need to cc everything or else you're just guessing
Old 12-09-2010, 03:25 PM
cc? im dumb when it comes to this stuff haha. i dont need exact. just close.
Old 12-09-2010, 03:51 PM
09camaro383's Avatar
The calculator I use gave me a 11.1 C.R
Old 12-09-2010, 03:54 PM
Old School Heavy
speedtigger's Avatar
64cc heads
4.03 gasket bore
piston stroke 3.622
What I have read about the LQ9 says:
4" bore x 3.622" stroke
factory 317 head is 71.06 cc
Deck is .005" out of the hole
piston volume is 0cc
I think the factory head gaskets are .060"
If it is a stock LQ9 and all you did was swap on some 64 CC heads, you are probably 10.9:1 ish with a stock gasket and a hair under 11.5:1 with a .040" gasket.
I use this handy dandy tool:
http://www.rbracing-rsr.com/compstaticcalc.html
Old 12-09-2010, 04:23 PM
your handy dandy tool came out to 11.47. thanks for the link!
