high oil pressure
Old 12-09-2010, 10:08 PM
ae13291's Avatar
Default high oil pressure
hello, car is a 99 z28 i use valvoline 5w30 full syn. i put in a new sending unit not to long ago, before the new oil pump i was running about 40-45 psi on idle normal temp. i put in a new cam along with a lingenfelter HV oil pump and i ported it and used the stock oil psi relieve spring but i shimmed it a little. the lowest the oil pressure would go on a hot day normal temps on idle is 55 psi. when i accelerate and go up to 2500 or 3000 rpms my gauge is getting very close to 80 psi. now is this normal or is there something i need to worry about. car has 96k miles.
Old 12-09-2010, 10:44 PM
FormulaWs666's Avatar
You put a high volume oil pump in your car......did you expect different results?
Old 12-10-2010, 04:18 AM
DSkyles's Avatar
A higher volume wouldn't mean a higher pressure. It's because you shimmed the stock spring. I have a melling high volume pump and put the stock spring in it, same oil pressure I had before. I'd say if it doesn't go over 80 it should be fine. I'm sure someone with more knowledge will fill you in.
Old 12-10-2010, 06:07 AM
davidws6's Avatar
I'm running the HV Melling 10296 and at a 750rpm idle it pushes about 50 psi. Above idle pushes about 60 > 65. I left the stock spring in it. When it's cold, it will hit 75psi above idle.
Old 12-10-2010, 12:03 PM
ae13291's Avatar
ok thanks for the responses guys.
