WILL -Comp Cams "Comp R" Hydraulic Roller Lifters work with my setup?
Old 12-11-2010, 06:01 PM
Stingerrr85's Avatar
Default WILL -Comp Cams "Comp R" Hydraulic Roller Lifters work with my setup?
Will these work wrk with my setup im replacing stock ones for security reasons in my ls1 ..
i just want wanna make sure i can throw these right in when i do my hyd cam swap to custom grind
Old 12-11-2010, 06:07 PM
vettenuts's Avatar
Better read the Comp literature, the R's require adjustable rockers and 0.002"-0.004" of preload. I would look elsewhere for lifters.
Old 12-11-2010, 06:08 PM
Darkman's Avatar
Comp recommends adjustable rockers with those because they require a very narrow range of workable preload specs.
Old 12-11-2010, 06:10 PM
so what lifters should i get?
Old 12-12-2010, 12:37 PM
Steve01SS's Avatar
Either the GM "LS7" replacement lifters or the standard Comp non-R lifters. Always measure for pushrod length regardless of which.
The R's have been mentioned many times, and not recommended.
Old 12-12-2010, 01:46 PM
jerflash's Avatar
ya the comp r lifters have been known to explode after only 2 weeks in a running car if not set up correctly...ask me how i know lol. just get the ls7 and do .080 or preload. thats what i have now and they are dead quite
