anybody running the gmpp ls6 heads?
Old 12-12-2010, 11:02 PM
laytoncamaroz28's Avatar
Default anybody running the gmpp ls6 heads?
i recently bought a set of gmpp ported and polished ls6 heads p/n 88958622. i was wondering if anybody here was running these heads and what kinda power and combos yal are running. times would also be nice. thanks
Old 12-12-2010, 11:19 PM
brian_rs/ss's Avatar
you'll be making at least 400 rwhp.
Old 12-12-2010, 11:55 PM
haha ok..... thanks
Old 12-13-2010, 09:21 AM
anybody else?
Old 12-13-2010, 11:32 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
I thought those were discontinued from gm?!??!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 12-13-2010, 11:46 AM
1lejohn's Avatar
I ran them for about 5 years ran a best of 11.10's on motor and 10.40's @ 132 on N2O. This was a 383 and 4l60E combo. The castings are very thin in the throat area. The pass head developed a pin hole and leaked. It was hard to find the leak. They make ok power and the valves are very lite weight and strong. Put some good springs on them and you should be good to go. Oh they are milled alot , check you manifold port exit to the head inlet. My LS6 manifold fit good the Fast had some issues.
Old 12-13-2010, 12:32 PM
Rise of the Phoenix's Avatar
How much did you pay for them?
Old 12-13-2010, 12:36 PM
13 Second Truck Club
LS1FREEK's Avatar
I know that LPE did the porting on those heads until 2007 and they milled them .055 and said they have 60cc chambers, but after 07, I think GM did the porting... Now they have 61.9cc chambers. I wonder how much they're milled now?
Old 12-13-2010, 01:00 PM
wow that sounds pretty good. im gonna run these with the 228r cam ls6 intake 42# injectors. since theyr milled so much did you have problems with ptv clearance?
i bought em used jason
Old 12-14-2010, 01:15 PM
david vericker's Avatar
I think they still sell the cnc 64cc non-milled version. Considering that the hollow and sodium filled valves are no longer available through GMPP,it's only a matter of time until the heads are no longer available too.
OP,see my sig for performance results. The nitrous shot was an additional 146 rwhp on the dyno.
Old 12-14-2010, 01:25 PM
LS1FREEK's Avatar
Well in the 2010 GMPP Catalog, they still have both milled and non milled sets available. You can download the catalog from their website.
Old 12-14-2010, 01:37 PM
I stand corrected. The SDPC website shows the 60.9 cc heads still available.
Old 12-14-2010, 08:03 PM
LS1FREEK's Avatar
SDPC must have their info out of date.. This was taken out of the 2010 GMPP Catalog:
Old 12-15-2010, 11:29 AM
1lejohn's Avatar
No PTV clearence problems on the stock short block or the stroker short block. You should be able to make 420-460 rwhp with them.
Old 12-15-2010, 12:46 PM
Actually my engine made 482rwhp n/a with the mods listed below.
Old 12-15-2010, 02:29 PM
when did you buy those heads?
Old 12-15-2010, 02:48 PM
wicked z28's Avatar
Im running them also on my 408 but I dont have any dyno numbers yet.I want to put some break in miles before I take it to CMS for tunning.
Old 12-15-2010, 08:30 PM
what size cam you running? did you have problems with ptv clearance? or they not milled that far?
Old 12-15-2010, 10:43 PM
wicked z28's Avatar
Cam specs are 246/250 627 in 630ish lift on a 112 dur and the wiseco pistons that are 11 cc valve reliefs I believe.And yes they are the ones that are milled 55 thous.,the car feels very strong and fast but im pretty sure im leaving some hp on the table do to the fact that they were not made for a 4" bore.But I purchased them brand new several years ago with the intentions for heads and cam but then decided to go all out with and LME 408.
Quick Reply: anybody running the gmpp ls6 heads?
