What hell white/yellowish inside oil cap??Pix here
https://ls1tech.com/forums/generatio...s-oil-cap.html
https://ls1tech.com/forums/generatio...l-cap-wtf.html
Lose the low temp thermostat (if apllicable) or drive the car long enough to get the oil temperature higher than the boling point of water.
Thanks,Dark
It's common for LS1..I will check it up and check on PVC any leaks. I checked the oil dispstick looks clean oil and the radiator (I use Dex-Cool orange) looks normal level. I drive daily in short trip often.
I notice the water temp. stay around ~ 180* all times without the electric fans on.
Should I check thermostat?
Thanks,Dark
Do you have 160 degree thermostat as opposed to a stock thermostat?
Setting aside the debate as to whether one can increase horsepower using a low temperature thermostat - they are not condusive to keeping the oil "moisture free" on daily drivers because they increase the time it takes for the oil to get hot enough to boil off water accumulation from ordinary condensation and combustion. Be sure you have the stock thermostat - usually 180 - 195 F or so.
Short drives, as vettenuts indicated, are killers.
Mine is the same way but only when it is cold outside.I have a 160 thermo in it.I live in Florida and hate to go to a hotter thermostat.It only gets cold here about two months out of the year.I get spark knock anything over 200 with the tune that is on the car.I guess I will just ease around till the cold leaves.
PENNZOIL omg that oil is so bad, I run it in all my cars and they always last 200k + without any trouble! That dam Pennzoil!
