need some advice
need some advice
i torqued the main caps and rod bolts to 18 ft pds. but the specs say Connecting Rod Bolts-First Design (First Pass) 20 N•m 15 lb ft
Connecting Rod Bolts-First Design (Final Pass) 60 degrees
Crankshaft Bearing Cap Bolts (Inner Bolts-First Pass in Sequence) 20 N•m 15 lb ft
Crankshaft Bearing Cap Bolts (Inner Bolts-Final Pass in Sequence) 80 degrees
Crankshaft Bearing Cap Side Bolts 25 N•m 18 lb ft
Crankshaft Bearing Cap Bolts (Outer Studs-First Pass in Sequence) 20 N•m 15 lb ft
Crankshaft Bearing Cap Bolts (Outer Studs-Final Pass in Sequence) 51 degrees
and i was wondering if 18 ft. pds. would be good enough or should i loosen them up and do 15 plus 60 degrees/ i didnt degree it on 18 pounds
