Cam Help Please
Old 12-16-2010, 10:45 PM
JKearney30's Avatar
Default Cam Help Please
I have a 98 Z28 Camaro. 3.73 gears in rear, pacesetter LT's, ORY, borla catback, and whisper lid. The car has 140,000 miles on it, is a cam a good or bad idea? Also should I do a new intake and throttle body first? The car is built for the street as it also has bilstein's all the way around, panhard bar, sfc's and LCAs. So I want a streetable cam and nothing outrageous. Getting tuned after cam also. Thanks in advance
Old 12-16-2010, 11:41 PM
Always2Slow's Avatar
cam is still a good idea as you will be refreshening half the motor. a cam with an intake duration less than 228 will be a good cam for you. a comp cams grind that comes to mind is 228 232. or eps grind 226 230.
Old 12-17-2010, 06:37 AM
garygnu's Avatar
what trans ?TSP 224r cam kit,tr224,EPS 222/226 cam.
Old 12-17-2010, 07:06 AM
ta-stanger's Avatar
I have a comp cam 228-230 588- 590 112lsa and it streets great! Plus has good HP!
Old 12-17-2010, 07:54 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Go to the dyno section and start looking. Many fun and streetable offerings. Do not go just by cam #'s and lobe design make a big difference and people often do not see that. EPS has been making some decent power and I would have you consider them. I have a Vengence VRx4 228/230 which is very fun as well.
Old 12-17-2010, 08:29 AM
JKearney30's Avatar
The car is an A4 but I just built the trans 2 months ago. It has been fully upgraded with beast shell, servo's etc. The only thing I did wrong is I put a new replacement stock converter instead of putting a stall while I had it out *dumbass*
Butt, with cam upgrade I will be putting a stall in as pulling the tranny isn't that big of a job.
Old 12-17-2010, 09:00 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
You might give us a call, we have tons of different options but it's best to discuss the car in detail before selecting a camshaft.
The good news is we have a crazy nice special going on the TSP camshafts right now!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
