LS3 Style heads on LS1....
Old 12-17-2010, 07:14 AM
EspaceF1Fan's Avatar
Default LS3 Style heads on LS1....
I was on Mast motorsports site and they had LS3 Style heads setup to fit the smaller bore LS1....
Is there anyone else out there offering small bore square/rectangle port heads?
Old 12-17-2010, 07:52 AM
Internet Mechanic
BlackScreaminMachine's Avatar
As far as I know, they were the only ones. I think its a great idea but in the end there are so many options for heads once you get to the 4.000" bore as seen in LS2's and the slightly bigger LS3's
I always expect my LS1 to break and the fear of spending good $$$ and just to spend it again when a 400+ cube motor going in can be annoying.
GMHTP did a article on the heads and made good power. I think the cam was a bit on the tame side but comparible to some other LS1 offerings.
Old 12-17-2010, 08:29 AM
I NEED to run an aluminum block in a swap I'm working on(weight distribution/handling reasons)
I happen to have a bare LS1 block.
I have a set of stock length Callies rods for said LS1
Just need pistons and I'm well on my way to a stout bottom end...
Problem is I have 853 heads.
I'm thinknig of running those and picking up some 243s to have ported later..but I like the cheaper intake manifolds for the square port heads,
What to do.....
