Piston to valve clearance
Old 12-19-2010, 02:15 AM
TA63's Avatar
Default Piston to valve clearance
I have a set of 243 heads with 2.05 valves installed and milled .020. Will I have piston to valve clearance issues dropping these on an LQ4 short block, or will the dished pistons provide enough clearance?
Old 12-20-2010, 01:36 AM
LS1C5Vette's Avatar
Stock cam? I am pretty sure you will or will be close, check it either way.
Old 12-20-2010, 09:11 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
We'd need more info about the specs on the cam and such to make a guess at this one.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
