Needing help on procharger build
Old 12-24-2010, 10:29 AM
velox65's Avatar
Default Needing help on procharger build
I'm planning my first FI build so I'm needing some help here's my base
Lq4 Punched .030
243 heads.
I'm looking for atleast 700whp the car will be a weekend car and strip.
What rotating assembly should I use? Stock crank? What cc pistons to run 92 octane?What procharger kit?etc etc etc I need help with just about everything related to FI na is no problem but 700 na is not easy.
Thanks
Old 12-24-2010, 02:10 PM
-Q-
-Q-'s Avatar
You should head over to the forced induction section and ask there...you'll probably get a better response.
I would guess you're looking at an F1A Procharger for 700whp. You might be able to get there with a D1, but easier with the F1.
Old 12-24-2010, 08:12 PM
garygnu's Avatar
Bob at Brute speed mite have a sale on what you are looking for.also look in the sponsors sale section towards the bottom of the main page.
Old 12-25-2010, 07:58 AM
velox65's Avatar
Ok I wasn't sure exactly where to put it being both internal and FI.
