How would this cam perform in a NA motor 226/230 116+1
Old 12-27-2010, 01:15 PM
crazyelf's Avatar
Default How would this cam perform in a NA motor 226/230 116+1
Im looking at buying this cam from a board member, It looks like it would be a nice sleeper cam and also give me a little more ptv clearance with the wider lsa.
the only thing holding me back is that it was spec'd for FI or Nitrous use. I was kinda looking for a sleeper style cam so would this work out well for me or will I be leaving a chunk of power on the table???
Old 12-27-2010, 01:33 PM
FSTR/TA's Avatar
IMHO you will be leaving alot on the table if not FI or spraying. The LSA is more along factory lines and the duration may make a lil power over a factory LS1 cam, but will really be similar to stock. Bring that LSA down to 114-112 and that biatch will wake the hell up with same duration and lift. What is the lift anywho?
Old 12-27-2010, 01:38 PM
crazyelf's Avatar
lift is .598 .600 there was a similar eps cam with stock 243 heads that put down 430whp through an auto. the specs there were 222/226 115. I figured with more duration and only one more degree lsa it would be in the same ballpark. I also have a set of 243 heads milled .025 I plan on using
Old 12-27-2010, 10:30 PM
crazyelf's Avatar
Any one else?
Old 12-28-2010, 12:27 AM
*02WS6TURK*'s Avatar
226/230 on either a 112 or 114. Go w/ a EPS custom cam. Personally I would stay away from a 116lsa.
