Help with heads
Old 12-30-2010, 12:13 AM
JeaneGrae's Avatar
Default Help with heads
I have a set of low mile 243's i bought a few mths ago, roughly 4k on them. My project plans have been slowed a bit due to winter weather and work. My questions do the heads need anything thing special utnil I can out them on? Lube, etc etc, if so exactly where and can you post pics if possible.
Old 12-30-2010, 12:20 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I guess they are fully assembled? You can always just take some fresh motor oil and rub it on there with your finger here and there.
Old 12-30-2010, 06:35 AM
garygnu's Avatar
clean them up and look for a valve seat leak.test the valve springs.
Old 12-30-2010, 06:48 AM
Darkman's Avatar
Spray them down with a light oil - WD40 is okay, but something a little heavier is better. Wrap them in plastic and store them with the sealing surface up in a box. If you leave them standing in the corner of a garage, someone will knock them over, and heads always fall on the sealing surface (it's like a rule).
