top end rebuild
Old 01-04-2011, 08:17 PM
brian_rs/ss's Avatar
Default top end rebuild
i'll be leaving for afghanistan soon and due to a change in plans i will need my car worked on in my absence so i can have it in tip top shape when i return. it will need to be able to make the trip from texas to camp pendleton CA. which currently i don't trust it to do. it smokes, it ticks, the clutch chatters, it wont shift above 5500, the motor mounts are disgusting etc...
OK, so here's the list that i've put together:
what is currently on the car:
stock 799 heads
ls6 intake
prof products 85mm tb
30lb SVO injectors
TSP 224r cam: 224/224 .581/.581 114lsa
comp magnum 5/16 x 7.400 pushrods
patriot gold dual valve springs
melling high volume oil pump(pn: 10296)
n-motion LS2 single roller timing set
mufflex 4" cat back
TSP o/r y-pipe with flowmaster 4" merge
pacesetter ceramic coated LT's
spec stage 1 clutch
slp lid
what needs to be done:
prothane polyurethane motor/trans mount kit(pn: 7-1908) $75
tick adjustable master cylinder(pn: TAMCKFB) $300
tick speed bleeder(pn: TPSBL) $50
GM slave cyl/T.O. bearing(pn: 15046288) $160
spec stage 2 clutch $385
spec steel flywheel $235 <----if needed
Fel Pro top end gasket set $210
Fel Pro head bolt kit(pn: ES72173) $50
comp 850-16 lifters $200 <----if needed
harland sharp roller rockers $415 <---if needed
custom length push rods $110 <---if needed
there is an oil consumption problem, most likely coming from the heads. this needs to be found and fixed. also a port, polish, and mill(roughly .025-.030). a leak down and compression test might be a good idea as well. the rings should be fine but i don't know for sure. i would think that checking the lifters and cam lobes for wear would be appropriate, i'll leave that to the discretion of the engine builder as well as the need for new lifters, rockers, and push rods.
so we are looking at around $2000 in parts, give or take. those prices were just pulled off of the internet as i found them. and i may not need some of what i listed, i just went ahead and threw in things i might need to prepare for the worst.
so i just need to know if i'm forgetting anything or if i pulled a n00b move with any of the parts i listed. and of course opinions and suggestions are welcome.
Old 01-04-2011, 09:38 PM
garygnu's Avatar
good luck and keep safe.I would maybe consider some YT rockers.save you old lifters and convert one to use for checking for proper push rod length.sell the others for the same reason.maybe consider a torquer or custom cam to go with the improved flowing heads.
Old 01-04-2011, 10:01 PM
depending on the communication i will have i am considering a custom EPS grind. or possibly the 234/246. which idk because that one seems a little fat on duration. we'll see, but eventually yes i will have a bigger cam, and i think i am pretty set on EPS. unless someone better comes along in the next 7 months.
btw any reason for YT over HS rockers?
Old 01-04-2011, 11:10 PM
01ssreda4's Avatar
I would definitely do new lifters and the new flywheel to go with the clutch.
Old 01-05-2011, 01:17 AM
yeah the stock flywheel has already been resurfaced once. and i'm sure the current clutch has done a number on it since then. it slips and chatters so bad...
Old 01-05-2011, 02:56 AM
01ssreda4's Avatar
Since clutches are obviously expensive items, I would always recommend a new flywheel, even on stock applications. I'm the type that replaces rotors when I do brake pads too
Old 01-05-2011, 06:30 AM
garygnu's Avatar
I have herd less problems about the YT rockers.the intake and exhaust rocker are mounted on the same shaft,I feel this make them more stable at high rpms and lifts.the can be found for a little $400.I like the EPS cam idea ,just ordered 1 my self.
Old 01-05-2011, 12:57 PM
i thought the HS were mounted the same way? i'll search around and see what i can find. who do you think would be the cheapest on them? TSP has them for like 480. where as the HS are 415. but when it comes down to it i don't really want to skimp on my valvetrain.
edit: are the YT6645 the ones i need? the bolt on non-adjustable 1.7?
Old 01-05-2011, 06:32 PM
garygnu's Avatar
I think you are right about the HS being shaft mounted,I can't tell by the pics.you can get the YT rockers(6645) at the WS6 store,and look at TSP also.
Old 01-05-2011, 10:37 PM
oh wow WS6 store has the YT for like $408 and the HS for $380.
and what about the scorpion performance rockers?
http://www.ws6project.com/user_stor/...oducts_id=2547
