FAST or LS6..heads or heads...
Ok,
So, I am going to start putting my car back together as I collect the parts. Long story short, I cracked a sleeve. previous set-up was a El-Torro cam box stock LS6 heads and a LS1 intake.
So sold the heads and I am left with a broken short block.
Now I am looking for another shortblock. Used preferbly under 80K miles. Something to last a lil and get me going again.
My goal is bottom of the 11's N/A or touch 10's. And add a 150 of juice.
So. here is what I am asking. I want to get a little more cam. Maybe 23x/24x? streetsweeper,polluter,something along those lines, or a custom grind. Should I go with say a ported stock casting. 5.3's or 799/243 or a Aftermarket. TFS220's, or maybe Darts. AFR's if I find a deal,lol And stick with a LS6 intake. Maybe a Ported LS2 (they flowing more than a LS6?)
or can I accomplish my goal (LOW 11's/High 10's) N/A with a Ported FAST 90/92 and the stock casting's Ported/Milled. I know the LS6 restricts the flow of even stock heads
The car is a 99 Z T-top car. Auto 4k Vig, 3.42 rear. On a slight diet. Probably around 3300-3350 w/out driver. Btw QTP 1 3/4 ORY w/ Flowmaster 4in merge. Walbro 255 and going with a SD tune
Now, I don't have any supporting mods yet (suspension), and its dumb to "have all dat motor and no traction" lol But, Its always easy to bolt on a Tq arm and Shocks than heads and such especially since the engine is already out.
Am I making any sense?
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Makes sense to me. The best head you can afford is going to generally be the best route. Aftermarket castings are the way to go if you can conjure the $$$. People sell heads on here all the time. Sure, you may have to cut them or clean them up, but if you can get some AFR's or TFS for a decent price you are doing good.
On a side note. There are SI cars that were pretty decked out suspension-wise hitting 11's all day. You have the stall for it. Just make sure everything can handle a 1.40 60ft.
ported 243/799's, EPS 234/246 .602/.607 111 lsa, comp 850-16's, YT or HS rockers, FAST if you can afford it(stay away from ls2's), then start working on suspension and rear end.
