799 milled?
Old 01-06-2011, 01:02 PM
txh0tb0i972's Avatar
Default 799 milled?
Ok im am lost when it comes to cc's and all the other stuff?
I have a guy wanting to trade me for my trex cam...they are a set of 799 heads but they are milled 30 thousandths ....
what cc's would that put me at??
I plan on building a 370 with mahle pistons which are these pistons http://www.summitracing.com/parts/MLE-LS1314030F04/
would i be safe with these heads?
what would that do to my cam selection?
will i be able to use pump gas?
pretty much i want to get schooled on any info you can help me out with!
thanks!
Santana
Old 01-06-2011, 01:18 PM
Phantom's Avatar
59.83 cc or somewhere around there...
I have a 6.0 with flattops or -3cc eye brows (4.005 bore). I run 91octane, 240s duration cam, nitrous, .055 head gasket (stock) puts my compression around 11.1:1
Old 01-06-2011, 01:23 PM
Jon@Texas-Speed's Avatar
That would be 59-60cc chambers. You should be fine with those pistons. They have a -4cc relief so unless you are running some kind of crazy cam, PTV shouldn't be an issue.
Jon
Old 01-06-2011, 01:29 PM
im looking to run into a ms3 cam or possibly a g5x2 cam...but leaning towards the ms3
Old 01-06-2011, 02:05 PM
Phantom's Avatar
we've run a 244/248 .612/.615 112LSA with those pistons and .030 milled 243/799's
Old 01-06-2011, 02:09 PM
On what vehicle? the truck?
what mods are done?
any track times or number?
Old 01-06-2011, 02:13 PM
Phantom's Avatar
It was on my buddies truck. .030 6.0, .030 milled 243 heads, patriot extreme springs, stock rockers, big converter, 4.56 gears. We tuned it on the street. I don't think he ever put it on the dyno. It ran real good though. Drove it daily, no bucking, 91 octane, 18-19mpg
Still has the same cam with .030 milled L92's and .040 Cometic head gaskets. It has a bum 4l60e trans with a stock converter in it for now, so no numbers or racing.
Old 01-06-2011, 02:15 PM
i take it this one is yours?
OK LP?
http://www.youtube.com/watch?v=eW2VDKey8yw
Old 01-06-2011, 02:17 PM
Phantom's Avatar
Thats my buddy's truck, yes
Old 01-06-2011, 02:18 PM
Phantom's Avatar
What's LP?
Old 01-06-2011, 02:20 PM
What's LP?
license plate
Old 01-06-2011, 02:22 PM
Now did he just bore it 30 and use stock crank and rods? or did he get a different rod?
Phantom's Avatar
Yeah, we're from Oklahoma
Old 01-06-2011, 02:24 PM
Phantom's Avatar
It's a stock crank, after market 6.125 rods, arp bolts.
My new motor will use a 4.030 diamond piston for use with a stock 6.098 rod. I have a set of LS2 rods I'm going to use
Old 01-06-2011, 02:30 PM
thats what i was planning on doing!
stock crank and rods! with either mahle piston or the diamond piston!
