02 LQ4 or 05' LQ4 which should I buy ?
Old 01-09-2011, 11:32 AM
adrynalinjunkie's Avatar
Default 02 LQ4 or 05' LQ4 which should I buy ?
I found a 02 and a 05 in a local yard that both have about 70K should I buy the 05' LQ4, since it has a little higher compression? Are there any differences?
It is looking like my 01' Z-28 has a spun rod bearing. Would everything from my LS-1 bolt up and cross over?
Old 01-09-2011, 12:03 PM
sman's Avatar
Going to have to drill and tap a hole in the front of the block for one of the alternator brackets, but otherwise, your good to go. Im running a 5.3 lm7 in my car now.
Old 01-09-2011, 12:06 PM
How do you know how deep to drill without going too far into the block?
Old 01-09-2011, 12:14 PM
camarochvy21's Avatar
is this true?
Old 01-09-2011, 12:52 PM
sman's Avatar
Measure the bolt you pulled out of your ls1, thats what I did. It was a little nerve wracking, but in reality, wasnt bad, bolt up alt using the rest of the bolts/brackets. Mark the center of the hole with a punch and drill away. Tap it and done.
Took less than 5 minutes to do.
Old 01-09-2011, 12:53 PM
sman's Avatar
Originally Posted by camarochvy21
is this true?
You think im going to lie about it? Yes, its true.......
Old 01-09-2011, 01:01 PM
-Q-
-Q-'s Avatar
You don't HAVE to drill and tap that third hole for the alternator. There are plenty of folks around here who have not and have no issues using 2 out of 3 holes.
Old 01-09-2011, 01:50 PM
Good to know that it can be done, without learning the hard way!
Old 01-09-2011, 01:53 PM
So back to the original question is there any difference between a 02' and a 05' LQ4?
Old 01-09-2011, 02:32 PM
99 2500's Avatar
Get the 05, has the LS2 connecting rods and full floating pins.
Old 01-10-2011, 03:07 AM
No one's calling you a liar, I have just never seen, or heard about doing it.... I now that I know you really dont need to do it, I wont be
Old 01-10-2011, 03:19 AM
70Novaproject's Avatar
Second that. For the fact that its an 2005 motor. Ls2 full floating would be in your best interest if you were racing hardcore; otherwise its overkill, the press pin set up would be good.
Side note from my recent tragedy, make sure you get a warranty, and check the bores before you fire it up. I recommend changing the head gaskets if you do not intend to change the heads. I was going to change the heads on my LQ4 with 56k on it from a 04 truck. Never intended to check the bores, just kinda happened that way. I found pretty severe rust, have to take it .030 over. End result was I got back $850 cause of the warranty.
Quick Reply: 02 LQ4 or 05' LQ4 which should I buy ?
