Which arp rod bolts u suggest???
Old 01-14-2011, 05:35 PM
bmf5150's Avatar
Default Which arp rod bolts u suggest???
Which arp rod bolts do you suggest??I'm just going to replace stock rod bolts,so I won't be resizing anything!!
Old 01-14-2011, 05:49 PM
JPH
JPH's Avatar
Originally Posted by bmf5150
which arp rod bolts do you suggest??i'm just going to replace stock rod bolts,so i won't be resizing anything!!
#134-6006
chrisfrost's Avatar
You should probably look at getting Katech rod bolts as they claim They are considerably stronger than stock without distorting the rods thus negating the need to have rods resized . They cost about $200.00 from what I understand . Good luck
Old 01-14-2011, 06:00 PM
2000ls1tranz's Avatar
id go katech thats what im going with an heard lots of good things with out resizing or honing
Old 01-14-2011, 07:36 PM
MYSTIC-1SC's Avatar
The Katech bolts would definetly be a good choice.
Old 01-14-2011, 09:30 PM
bmf5150's Avatar
Ok,but how about for arp?I know there are two different ones!
Old 01-14-2011, 11:43 PM
99 Blue Bird's Avatar
if u use ARP bolts u need to have the rods resized. thats y everyone is telling u to look into the katech bolts since resizing is not necessary to use them. u might want to see what your local machine shop charges to resize rods. cost me 40 dollars plus 100 for the ARP 2000 bolts. so it was only 140 compared to the katech 200 dollar bolts.
