ms3 cam head choice?????????
Hey wussup guys im looking for a set of heads that I can make about 450-460rwhp with. So far I have done to the car is ls6 intake,ms3 cam, longtube headers, o/r y pipe, corsa exhaust, ported tb, 3.73 gears, 125 shot nitrous. Im switching intakes to the bbk ssi intake here in about a month but im looking for a set of heads that will get me to about 450-460rwhp with the timing tooken out for the nitrous. Help needed. Thanks guys
I have an 02 z06 with an ms3, prc stage1 ls6 heads and ported fast 90/90 that made 469-415. I dont think you can run the stage 2.5 ls6 heads with an ms3 without flycutting, the bigger valves will hit.
1 Post
I've got PRC 2.5 5.3 heads and they seem to do pretty well. Car ran 11.01@123 last week with a small 3600 stall and that was at 3300 pounds. The car made 429 with the converter unlocked through a 12 Bolt with 4.10's. I could have spent more and went with a better head but I like them because they were cheap and effective.
LS1TECH & Trucks Sponsor
I think it depends a lot on your budget. The best set of heads we can offer for that cam would be our 215/227 aftermarket casting. Aftermarket casting heads offer a thicker deck so you have more clearance to work with as far as valve size and combustion chamber size.
I ran our stg 2.5 MS3 heads with the MS3 and I thought it worked out great. I had great driveability and gobs of power when I needed it. Our stg 1 LS6 heads will also work but I prefer to see people run the 5.3l heads. The smaller runner and combustion chamber really stretch out the low end power on that cam.
1 Post
John, I originally was going to do an LS6 head per many peoples recommendations but when I spoke with you on the phone you pointed me to the 5.3 head. Needless to say I'm 100% satisfied with that advice and never got to thank you. My MS3/5.3 head combo works great and has tons of power on a small budget.
