Old 05-18-2016, 06:15 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
How to drop engine from bottom with k-member
Old 01-18-2011, 11:07 PM
2000ls1tranz's Avatar
Default How to drop engine from bottom with k-member
once everythings unhooked an bolts to kmember are removed an car is lifted up how do u keep it from tiping over an how it u keep the k an engine sitting up right????what do u guy think i should put it on to roll it out from under car???
Old 01-18-2011, 11:24 PM
King Nothing's Avatar
like this and roll it out on the tires, just take off the front bumper so the shocks clear the body
Old 01-18-2011, 11:31 PM
btw when i put the new engine in this is what kept it balanced till i put the shocks in place
hmm i see wasnt sure ...when me an my buddy changed his k member it didnt have the engine on the k member an it wanted to like tip back an stuff...maybe the weight of the engine being on it that stops it from doing that?...thanks for the help
Old 01-18-2011, 11:35 PM
also i see in the pic ur heads are off ...did u have to take them off to do this? would the spring an shock or spindle hit the heads if not????
Old 01-19-2011, 02:33 AM
99huggerorangeZ's Avatar
or use a wooden dolly to roll it around on.
Old 01-19-2011, 11:56 AM
dphc18's Avatar
Just pull everthing out with trans attatched this will balance everything
Old 01-19-2011, 03:37 PM
1QWIKBIRD's Avatar
Making it way too difficult and dangerous using two jacks. Put the rear wheels up on blocks. Make all the disconnects. Remove front wheels. Slide dolly (2'x3' made out of 2"x3" 0.95 wall tubing with 3/4" plywood top and super duty swivel casters) under the K-member. Attach the cherry picker to the front rad support using movers slings (or some other strap designed for vertical lifting), then lift the nose of the car off the k-member. Slide jack stands under the car. Release the picker and roll the dolly along with entire motor/tranny etc out. Safe and easy.
Not my idea, but it sure does work.
Attached Thumbnails How to drop engine from bottom with k-member-out-bottom.jpg
Old 01-20-2011, 09:18 AM
Rich92RS's Avatar
Drop the motor and trans together, and place a wooden dolly under the trans. The only real benefit to taking the wheels off is making it easier to unbolt two of the kmember bolts, and disconnect the wheel speed sensors.
Don't trust one dolly under the kmember. There was a thread not to long ago about how the dolly split in half, making it a major pita to drag out.
Cylinder heads dont need to come off, just support the middle of the kmember with a jack/dolly as you wheel it out.
Your talking about motor w/kmember out of the car correct? If so it will still want to tip back with or without the motor. So after removing the trans, carefully support the rear of the motor.
Old 01-20-2011, 05:31 PM
4U2BNVS's Avatar
Boy am I glad I have a lift in my shop. Sounds lime to much bs that you all have to go thru
Old 01-20-2011, 05:32 PM
4U2BNVS's Avatar
Like* damn I hate auto correct on my droid.
Old 01-20-2011, 05:38 PM
Squirts11's Avatar
x2. Did it for the first time this past summer. Wasn't bad really, but just ensure you've disconnected everything. I'd drop it a few inches then recheck, repeat, etc. I also dropped the engine/trans as one unit. Seemed much easier that way.
Old 01-21-2011, 02:49 AM
yes ...going to change rod bolts an put new k member in
Old 01-21-2011, 02:52 AM
removing k-member engine an trans just use one wooden dolly under k member in the middle??? where can u buy this dolly?
Old 01-21-2011, 03:53 AM
sxracerb25's Avatar
Use more than 1 dolly. I have metal wheel dollies from Harbor freight that worked well. One under K-member, one under each rotor (probably unnecessary but I like to be safe), and one under the transmission. Just take your time and make sure everything is supported
Old 01-21-2011, 06:29 AM
pwrtrip75's Avatar
I put the front up on blocks. Hook a hoist to the engine, unbolt everything, then lower the engine/k-member onto a cart, and then hook the hoist up to the bumper mounts and lift the car up. Pretty easy. A little wooden cart makes life mush easier.
Old 01-21-2011, 09:03 PM
well #8 rod broke in half and took out cylinder walls for cylinder 7 and 8 so yep the heads had to come off for my to find it, plus i sold the heads off the car since the didn't have any damage to them.
i never said it was the safest way lol it did work and the car never moved an inch in my control
keep an eye on the brake lines, they like to get hung up
Old 04-29-2015, 04:55 PM
ls1jorge's Avatar
Bump anyone else has pics or more info on droping k member?
Old 04-29-2015, 08:19 PM
RockinWs6's Avatar
Pull it from the top, honestly pulling it from the bottom is insanity. So dam easy from the top.
Old 04-30-2015, 03:55 AM
OutFoxed's Avatar
I have no prior F-body experience and have just recently dropped 2 drivetrains from the bottom with no help, no lift, no engine hoist. I used the method posted above with two jacks. Pretty easy and I used the following link for info.
https://ls1tech.com/forums/general-m...ls1-fbody.html
Quick Reply: How to drop engine from bottom with k-member
