question about oil galley plug,barbel?
Old 01-22-2011, 05:28 PM
bmf5150's Avatar
Default question about oil galley plug,barbel?
im installing the oil galley plug on the back of the motor,is the back of the plug suppose to be flush with the block surface?thanks
stan
Old 01-22-2011, 06:33 PM
Darkman's Avatar
http://www.hotrod.com/techarticles/e.../photo_05.html
Old 01-23-2011, 02:56 AM
racer7088's Avatar
stan
Yes it is.
Old 01-23-2011, 09:28 AM
brooknasty's Avatar
the barbell restrictor sticks out a little bit and the o ring end toward the back of the engine
Old 01-23-2011, 10:43 AM
bmf5150's Avatar
Yeah the one I took out stuck out a little bit,the new one when I put in was flush with the back of the block!wanted to make sure that's ok!!!
Old 01-23-2011, 09:21 PM
99Bluz28's Avatar
I know my GM service manual says it's suppose to be slightly recessed.
Old 01-24-2011, 10:34 AM
racer7088's Avatar
After running a few minutes it will push out till it hits the back cover as it can't go any further and it is designed that way so you are good.
Old 01-30-2011, 04:11 PM
tnmotown's Avatar
To the OP, is this what you mean? I'm running into the same problem
It pretty much stops where it hits the o-ring and the back part of the heads sticks out just a bit of the block. I didn't want to put the cover on until I knew for sure.
Just want to double check. So is this fine then???
Old 01-30-2011, 05:31 PM
99Bluz28's Avatar
The photo says it all.
Old 01-30-2011, 05:56 PM
tnmotown's Avatar
Nice photo. But mine doesn't go all the way in as it gets caught up on the o-ring part. Would I just tap it in with a hammer or something?
Old 01-30-2011, 06:01 PM
rpmauto's Avatar
put a little oil on the o-ring to lube it. You dont want to tear the o-ring.
Quick Reply: question about oil galley plug,barbel?
