How long is it safe to keep heads off & cylinders exposed?
Going through a head swap right now, & due to some issues I won't be swapping new heads on for a little while. I have everything cleaned up nicely, but wondering how long it's okay to sit uncovered in my garage? Can I just cover the engine with a trash bag, or do I need to wipe down the cylinders with something?
Literally drinch the cylinder walls with motor oil, gear oil or anything petrol based of that nature. Rotate the motor over by hand to make sure everything is getting coated. One rotation should do. And then check it often if it is humid out. Cylinder walls can pit very quickly if left bare
