cam i please have some cam help
Old 01-24-2011, 04:27 PM
firehawk196's Avatar
Default cam i please have some cam help
i was looking around and seen some cams anyone ever use them by the way my springs are good to a .580:
226/229 .575/.578 112 or 114 or 116 LSA
220/220 .581/.581 112 or 114 or 116 LSA
they are regrinds and im seeing lots of them around lots of people use them and other rather new idk any help will be great
Old 01-24-2011, 04:32 PM
Cosmos's Avatar
Thats too close. I wold get at least .600 lift springs.
Old 01-24-2011, 04:33 PM
dont have the extra money and there on the car already
Old 01-24-2011, 05:22 PM
djfury05's Avatar
No its not.. depends on what type of springs he has on there.. brand/design/loads etc
Old 01-24-2011, 05:26 PM
LTX355's Avatar
Need to let us know what springs u have... if they r ls6 springs plan on changing them for either of those cams...
Old 01-24-2011, 05:48 PM
i got them new from a guy on here they were in the gm bags and he says that the ones with the yellow markings are good for a .580 so i trusted him ya no thinking we are all here doing the same things y would i get screwed
Old 01-24-2011, 05:49 PM
Cosmos's Avatar
You would run a .581 lift cam on .580 lift spring? I suppose you would run a .598 lift cam on a .600 lift spring then blame the spring for failure when it breaks.
Can he run that setup? Of course he can. Will it hold up and work? Yes, but for how long?
Another option you can do is run a gm hot cam or the asa cam with your springs.
ASA cam
.525/.525 228/236 on a 110 lsa
Gm Hot cam
.525/.525 219/228 112
Old 01-24-2011, 05:53 PM
how will those cams work ?? did u guys use them?? and the lsa is too tight i dont need it to lobe like shes gonna stall btw its a m6 car
Old 01-24-2011, 06:13 PM
Cosmos's Avatar
I think they would work well, the hot cam would more than likey have the best street manners but a lot of that depends on your tuner. I would run the asa personally but I like lope.
Neither are going to give you max power but they will be fun on the street and will be easy on your valve train.
Old 01-24-2011, 06:15 PM
Cosmos's Avatar
I have a grind close to the asa. It lopes great and drives well. power from 2k up, pulls to about 6.4k with an ls6 intake. My max lift is .621, been awhile since I looked at the card. Im using patriot dual gold springs (.650 max lift)
Old 01-24-2011, 06:33 PM
KevinR's Avatar
Not trying to be an *** here, but if you don't have the money for all of the corresponding parts, then I would just hold off and save up some more money. Do it right the first time.
Old 01-24-2011, 06:36 PM
LTX355's Avatar
U can run the low lift xfi lobes like what the old faithful had... 216/220 or maybe the xe lobes for a decent time
Old 01-24-2011, 07:03 PM
Cosmos's Avatar
I agree but thats not what he was asking so I didnt respond with that. I agree with KevinR, hold off until you can afford a good cam kit, you will be much happier. You are really limiting your cam choices with the .580 lift springs.
Do you want all out power or do you just want some good power out of it? If you just want to up the ante a little and use those springs, the hot cam would be a good pick for ya.
Old 01-24-2011, 07:57 PM
guess ill wait then
Old 01-24-2011, 09:07 PM
djfury05's Avatar
ASA cam
Gm Hot cam
Most springs are underrated for that reason.. so people don't over do it.. would I run a cam with .580 lift on .580 max lift springs that I didn't know anything about and took a guy's word for them, no I would not. I am running PSI beehive maxlife endurance prepared springs .620 lift and my new cam going in is .62x/.62x. Its not all about the springs either. Lobes/rockers/wipe pattern/proper length pushrod for a perfectly set up geometry in the valvetrain is what counts also.
Am I disagreeing completely with you, no. As you said he "could" but how long it would last is the question.. lots of variables here. I agree he should change out the springs for something better and be able to comfortably run a cam with higher lift than the ASA or hot cam. Waste of time and money puttin either of those in IMO of course.
Old 01-24-2011, 09:19 PM
KevinR's Avatar
guess ill wait then
It'll be worth it. If you go with a smaller cam, you will probably wish you had gone bigger.
Quick Reply: cam i please have some cam help
