LQ4 piston to valve clearance
I have A 02 lq4 I did a cam swap and didnt check the ptv clearance, the engine is all together and installed in the car but still have a bunch of work left to get it running. The heads havent been milled and has the stock dished
pistons the cam I used has 230/236 duration @50 611/612 lift and 116 lsa
Do you think I will have problems with ptv clearance?
Ya I wish I would of checked it I had read a post were someone installed a larger cam in a LQ4 and didnt have any problems so I didnt even worry about it when I put the engine together
What is the largest cam that has been installed in a stock LQ4?
