where will this 383 build put me?
okay guys im getting pretty pumped about this but be perfectly honest what i should be putting down for numbers
Build:
Factory MAFs Descreened
Fast 90/90
TSP 383 stroker kit 11.25:1
PRC 5.3L stage 2.5 heads worked "Flow chart attached below"
MS4 cam 111 degree LSA
Kooks 1 3/4" LTs
3" electric cutouts
Yank SS3600 in A4
stock rearend 2.73's "probably won't last very long"
http://s1130.photobucket.com/albums/...=flowchart.jpg
http://s1130.photobucket.com/albums/...artnumbers.jpg
Build:
Fast 90/90
Kooks 1 3/4" LTs
3" electric cutouts
Yank SS3600 in A4
did you already buy the kit? If you did it should be fun, if not and you have more budget i would look into building a 408 to see what the price difference is vs gains.
You also might want to ditch that MAF and go SD as that will be a restriction on your intake side unless you can pony up a few more dollars and get a bigger one. If not it wint hold you back too much.
Build:
Fast 90/90
Kooks 1 3/4" LTs
3" electric cutouts
Yank SS3600 in A4
Build:
Fast 90/90
Kooks 1 3/4" LTs
3" electric cutouts
Yank SS3600 in A4
yes all the parts ordered or previously owned by me. so this will be how it goes together for now. I might buy 100MM Mafs later but not right now. So i was thinking between 430 and 460 tops don't think you can make 500 with these heads.
