should i add rockers to my setup???
Old 01-30-2011, 10:01 PM
chadnol10's Avatar
Default should i add rockers to my setup???
Ok so here is my setup 232/236 .590 lift comp cam with dual valve springs that can handle up to 660 lift. Chromoly pushrods 7.4, LS7 lifters I have TSP stage 1 heads. I have the stock rockers on now. Should i stay with the stock rockers or what do you guys recommend? Car has about 435Hp how much would i gain from rockers?
Old 01-30-2011, 10:26 PM
Greekey's Avatar
My advice is for you to stick with stock rockers and get the trunion upgrade for them. Their available from Texas speed already done to them or you can buy the kit yourself and install the trunion upgrade yourself. There I think around 230?Maybe?...Also, make sure you measure your pushrod length with an adjustable pushrod length checker to be sure you still need 7.4.
Old 01-31-2011, 12:08 AM
Whiteaw57's Avatar
^^^^^agreed
Old 01-31-2011, 12:17 AM
dphc18's Avatar
trunion kit for sure!
Old 01-31-2011, 12:28 AM
Whiteaw57's Avatar
All youll really gain with rockers is MAYBE 25 hp after another $400 tune and heavier valve train, i.e. worn out valve springs. Trunion upgrade and let her rip
Old 01-31-2011, 06:34 AM
Darkman's Avatar
I don't think adding roller rockers would add any horsepower, unless you dropped a couple grand or more on some Jesel Pro Steels.
Old 01-31-2011, 01:15 PM
99C5Coupe's Avatar
If your heads have bronze valve guides, most aftermarket heads do, the wipe pattern on the valve tip from the rocker arm will wear out the guides. Roller rockers can be adjusted with shims to center the wipe pattern and make it narrow.
Old 01-31-2011, 01:21 PM
bearcatt's Avatar
Trunion upgrades or yella terra rockers.
Old 01-31-2011, 05:36 PM
garygnu's Avatar
TSP heads use powder metal guides. keep the stock rockers,consider the trunnion bearing upgrade .no big power gain with full rollers ,maybe 5 hp.
Old 01-31-2011, 10:02 PM
Whiteaw57's Avatar
when I said 25 hp i was for some reason thinking he was going from 1.7s to 1.85s. Idk why. I guess i read another post with that. but stock geometry is spot on. Its the safest bet unless youre getting into some serious stuff
Old 02-01-2011, 04:10 AM
vettenuts's Avatar
Originally Posted by Whiteaw57
....but stock geometry is spot on. ....
Curious, have you measured? When I measured with an aftermarket cam (smaller base circle and bigger lift) it was nowhere near "on".
