5.3 cam
Old 02-04-2011, 06:49 PM
boyd95SS's Avatar
Default 5.3 cam
i recently got a 5.3L motor and was looking at putting a set of AFR 205 heads with a 228/228 cam, however i was told i should go a little bigger because i want more lope like a 232/236.
is that too big a cam for a heads/cam/longtube 5.3 motor?
some people say the 228 is a big cam for 5.3 and some told me the larger was ok
help
thanks
Old 02-04-2011, 11:15 PM
LTX355's Avatar
a 224 cam is a nice size for the 5.3 i wouldnt go over 228 unless u plan on increasing compression above 10.1... big cams kill dcr and that is gonna take all your low end.
Old 02-05-2011, 06:46 AM
garygnu's Avatar
it depends on your combo and what your doing with it.is it a street car or a all out race car?
Old 02-05-2011, 10:08 AM
boyd95SS's Avatar
as far as compression i am just going to get the thinnest head gaskets i can.
and it is just going to be a street truck hehehe, i am removing the piece of crap lt1 and putting in the 5.3 in a `95 s10
thanks
Old 02-05-2011, 06:24 PM
garygnu's Avatar
talk to Patrick-G you would benefit from a custom cam with those heads.what gears and and trans?you will need lots of toque to move a heavy truck.too much lope- over lap will make it slow out of the hole.
Old 02-06-2011, 12:30 PM
boyd95SS's Avatar
it has a ford 9in with 3.70 gears and a 4l60e
Old 02-06-2011, 12:43 PM
garygnu's Avatar
how big a stall converter will you go with.the the higher the stall the bigger the cam you can work with.how much dose a s10 weigh?how tall of tire?I was thinking of a c1500 weight earlier,sorry.the s10 is a good platform for a hot rod.
Old 02-06-2011, 08:17 PM
boyd95SS's Avatar
it weighs about 3800pds, ill probly go with a 3200 stall or so on a 275 tire
Old 02-07-2011, 01:49 AM
NemeSS's Avatar
No need for afr heads on a 5.3. A stock milled set of 243/799 will get the job done with l33 5.3HO/5.7 head gaskets and a patg spec cam
Old 02-07-2011, 07:26 AM
boyd95SS's Avatar
the only reason would like to get the afr heads and cam is because i can get the combo at half price with 5k miles on them from a known source, also have heard lots of good out of the 205's
Old 02-07-2011, 08:12 AM
NemeSS's Avatar
If that's the case get the afrs.ditch the 5.3 and slap dem bitches on a lq4 or lq9 with the cam
Old 02-07-2011, 08:52 AM
sman's Avatar
Check my sig for numbers and parts.
Cam is right on the limits for the motor, low end is pretty much gone, but shes a screamer up top. Kinda hard to tune, plan on bumping your idle a good 150-200 rpms to keep it running. I dd the car in the summer and sometimes its just to much. Bumping the CR should help a ton.
Old 02-07-2011, 08:55 AM
5.3LJimmy's Avatar
For a 3800 pound truck you really should stay at or below 224 degrees on the intake side. The Comp 224/228 on a 112 LSA does good in the 5.3 and would work well with the AFR heads. This cam will lope plenty in the 5.3 and is the max I would recommend.
Old 02-07-2011, 07:29 PM
boyd95SS's Avatar
thanks for the replys guys,
i thought the 5.3 was designated lq4, what is it called then?
my lt1 made 320/295 at the wheels and it had a nasty first and second then fell off in third gear, what kind of power and times am i looking at with the new motor heads/cam/headers?
and the heads/cam come with the right length pushrods, if i want to say shave the heads and put thin gaskets, what will that do to the pushrods
Old 02-07-2011, 09:29 PM
NemeSS's Avatar
Lq4 is the 6.0 engine not the 5.3
Old 02-07-2011, 10:05 PM
91_rs-teal's Avatar
all the GM Vortec Engine codes
http://en.wikipedia.org/wiki/GM_Vortec_engine
Old 03-12-2011, 12:20 PM
boyd95SS's Avatar
ok well that afr deal fell through so i went ahead and bought a 226/229 58x lift and 112lsa and some ls2 heads. however, i am now going to bore it to an ls1 bore and go with forged internals and spray, so is that cam going to be big enough in an ls1
Old 03-12-2011, 12:43 PM
remauto1187's Avatar
There are quite a few RPO codes for the 5.3L. Different variations.
You might be thinking of the LM4 which is a 5.3L Alum heads and block.
Old 03-15-2011, 07:35 PM
boyd95SS's Avatar
anyone?
Old 03-15-2011, 10:35 PM
zacht's Avatar
plenty of people run 224's and 228's and make great power in a 5.7. you'll be fine. the wilder side of the 5.7's gets up into the 240's and .6-.65 lift....
Quick Reply: 5.3 cam
