LS1 windage tray on a stroker LS2
Old 02-08-2011, 08:29 PM
jkkaz's Avatar
Default LS1 windage tray on a stroker LS2
This might be in the wrong section to ask, but I have a stroker 402 LS2 (short block) with H-beam rods and I want to transfer some of my old LS1 parts on to the stroker short block. What I'm trying to do right now is reuse the old windage tray. It hits the rods, but it seems like there is enough length on the windage tray bolts to simply add a spacer to get the windage tray to fit. Is this possible or is there a better windage tray to use?
Old 02-09-2011, 09:29 AM
Jon@Texas-Speed's Avatar
If you are using a LS1 pickup and oil pan it is the one to run. You have to space the windage tray down to clear the rod bolts on the 4" crank motors. You can go to your local hardware store and pick up some 3/8" flat washers and use them to space the tray down. Typically takes 2 washers per stud. Put the windage tray over them and torque it down. Make sure it clears and finish assembly. Let me know if you have any other questions!
Jon
Old 02-09-2011, 10:25 PM
jkkaz's Avatar
Thanks for the reply, that seems to be the easist fix. I saw some SLP spacers measuring out at .11. I stacked a couple of washers and got reasonably close at .14. I also noticed that bolt holes have quite a bit of slop and you can slide the windage tray over about a eighth of an inch to gain just a bit more clearance.
Quick Reply: LS1 windage tray on a stroker LS2
