name that sound. 99SS
Hey guys just got a 98 SS with 60k on it and I'm trying to diagnose an engine sound. It wont make it on a cold start, takes a few minutes to make it at idle and its worse point is around 1800 rpm give or take 100. You can hunt for it on start up and it will make it right at that rmp range but once it warms up its constant. I put some videos on youtube. The top one was after a well due oil change, but it was already warmed up and idleing at 1800 when I started recording, other two were a few days ago before oil change.
www.youtube.com/chriz2000wv
tell me what you think.
oil pressure is good. can i check/change push rods without taking the heads off? at one point the other day when it was warm we all agreed it was coming form the passanger side....but im not positive now
I watched your video and the oil pressure looks a little low. Warm the engine up completey and let idle. You should have 40 psi. Also make another video and rev it suddenly from a idle but not high. If its a rod bearing it will tap badly.
I should be able to get another video up in the next day or so. But if it is something bad, like the bottom end or a spun rod I dont want to drive it. So I wont put it on the road aka make her legal. And since I probably wont be able to come up with a few thousand dollars to rebuild it what is the car worth as is? like I said it just turned over 60k. shes a 7 or 8 out of 10.
Didnt have time to do anything today but move it. But when I pulled it in today I noticed the psi was well above 40 on COLD start up, and of course the mystery sound was nowhere to be heard. just not sure about warm yet. Kind of hate letting it warm up but I guess the damage has already been done? If it needs rebuilt, is there a chance the block might be ok? because arnt the 98 blocks super think and cant be bored? even if i do have it done id want it stock
Yes, you can. Just pull the valve covers, and rockers and you can get to the pushrods. Honestly, I've bent a pushrod before, and it kinda sounded like that. I guess you can expect the worst and hope for the best on this one. It's hard to tell from the video, but is the sound coming from the top?
I'd pull valve covers first before worrying aboiut what I was going to do or purchase.
That might be caused by the rollers coming out of the rocker arm (appears to be a common thing).
Search "trunnion upgrade" for more info. One of the common complaints was a "sewing machine" sound coming from the top of the motor.
Diagnose first. everything else second!
either today or tomorrow im going to try to do that. and also here in a little bit im going to go get a mechanics stethascope and see if i can narrow anything down while its cold and barley making the noise. also how can i tell if the rock arm is bad? and if i find the bent rod is it as simple as putting a new one in it, tightening the rocker arm bolts to 22lbs, and putting the cover back on? that would be too good. but like you said...hope for the best expect the worse.
ok...should be another video up in a second from inside the car, warmed up, hot. showing oil pressure...
the one uploaded today
