bouncing oil presure gauge
so is this normal, i broke the oil sending unit putting an LS6 intake on and replace it, ever since then the oil gauge will bounce at idle, but it only does it sometimes and not all the time. did compression test and got between 209 and 198psi through out all cylinders, is there anything wrong or does this happen sometimes. now it is probably about 20% of the time it will do this and it will only do it at idle, any suggestions?
Ever since I've had my '99, when it warms up, the damn oil pressure will only go up slightly as RPMs raise, and once I back off the throttle, the OP will jump up a good 10-12lbs and then come back down... weird...
