PRC 215cc heads + MS4 Question
I am in the process of buying a set of PRC 215cc heads. I would like to know what chamber size is needed in order for these heads to run with an MS4 cam in a LS6 block with no flycutting.
Thanks !
Thanks !
LS1Tech Premium Sponsor
Just give me a call and we can get it setup no problem! Any reason you don't want to go with the 227's??
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
__________________
