stroker 408??
The 6.0 isn't that expensive, and it will be less stressed to make into a 400+ cube motor than a 5.7liter. You can always turn the 5.7 into a 383 if you want. Don't get hung up on numbers so much.
I thought you were saying that the 99+ blocks were 3.908 bore compared to the advertised 3.905.
If you go aluminum, I would only go with a .005" hone and make a 402 or go .010" and build a 404 c.i engine. Going .030" on a LS2 block is a bad idea. The sleeve is going to start getting thing. You can resleeve them or even a LS1 block but that is going to start getting expensive quick. If you are wanting an actual 408, the LQ4 or LQ9 blocks are the way to go!
Jon
Jon
