t rex cam what do you guys think of it
planning on putting a t rex cam in my ta what do you guys think of it. what power does it make. how well does it wrk with stock heads. if i were to upgrade heads what would you rec. thanks
Captain Double Post
Its a massive cam that's for sure,and I run a ms4 in my 99 ss m6,if your gonna run this cam I would fly cut no matter what anyone tells you,also rod bolts would be a good idea ,your gonna have to spin it really high,also need a very tall gear,4.30s or higher,it makes a lot of peak power for just a cam ,I have seen guys claim around 435,its really what your building your car for,if its pretty much just a race car its not a bad choice,but if its mostly a street car I would go with something else,any one that is gonna give you advice on this cam needs to know a lot more about the car,your goals,m6 or auto etc,
you are running the magic stick 4 cam what nubers didi you get from it. can i use that cam with stock heads. my car is a street car with ocassnal track. its a 01 ws6speed ls6 intake and headders and full echust slp intake. do you like the ms4. whare did you get it. i hear you can get 80hp out of it. thanks.
