6.0 Circle Track
Old 02-15-2011, 11:00 PM
derricklong38's Avatar
Default 6.0 Circle Track
Been lurking around here for a while. And it will be a couple months before the build gets off the ground.
Engine must been all steel, so the 6.0 Iron heads and block it is.
$1500 buy rule in place. 7400 RPM Chip
most of the money will go with the intake/distributor drive
Stock crank. is there a 6.125 stock rod? Read stock length it 6.098 is that correct? ARP Rod bolts. Stock type pistons (Flat top)
Still searching on minimum head CC's, and max lift without having to try to cut pistons on valve relief.
I found a thread not too long ago, of what all interchange. pretty sure most of it all does. have to find it again
im worried about the pushrod,lifter, rocker area. Any ideas on them? LS7 lifters?
have some of the parts rounded up, nothing machined, or cleaned yet.
Please feel free to comment in any way. You wont hurt my feelings.
