new 5.3 block was told its an ls-6 with smaller sleeves true or not ?
Old 02-16-2011, 06:51 PM
formula c3's Avatar
Default new 5.3 block was told its an ls-6 with smaller sleeves true or not ?
anyone know if this is true + what they can be safely be bored too
Old 02-16-2011, 06:56 PM
kinglt-1's Avatar
most 5.3 blocks were iron when the ls6 block was in production, so I am going to say thats false... although I could be wrong.
Old 02-16-2011, 07:11 PM
formula c3's Avatar
its the new alu. truck block. so i'm told
Old 02-16-2011, 07:21 PM
kinglt-1's Avatar
I read that you could resleeve it to a 5.7 bore, but not sure if they are the "same" block.
Old 02-16-2011, 07:26 PM
formula c3's Avatar
was told the sleeves are just thicker and could bored safely to 383. no resleeve just bore them.
Old 02-16-2011, 08:03 PM
kinglt-1's Avatar
http://www.ls1.com/forums/archive/in...p/t-44289.html
Old 02-16-2011, 08:29 PM
KCS
Moderator
KCS's Avatar
That info is false, you can go to 3.905" on those aluminum 5.3L blocks.
Old 02-16-2011, 08:44 PM
kenp's Avatar
I have a 5.3 aluminum truck block bored to 3.905.
Old 02-16-2011, 09:08 PM
Brian Tooley Racing's Avatar
I have a 5.3 HO block and a 97' LS1 block and the OD of the sleeve in the 5.3 block is BIGGER! So yes, 3.90" bore is no problem.
Old 02-16-2011, 09:36 PM
garygnu's Avatar
great thread,I would like to find a block like that for a 383 build.dose this 5.3 block have windows cast into the lower block?what yrs and casting number.
Old 02-17-2011, 09:09 AM
kinglt-1's Avatar
Good info thanks for clearing this up! I found lots of different answers in different threads I searched...
